Activity › Forums › Panasonic Cameras › Can I buy a PAL version of dvx100b
  • Can I buy a PAL version of dvx100b
    Posted by Englishman on December 22, 2005 at 1:41 pm
    I’m new to this Forum so hello.
    I have decided to purchase this camera for many reasons and after using this forum for opinion…thanks
    Is there a PAL version available?
    What are the differences?
    What is a dvx102BE?
    Can anyone suggest a good retailer?
    Thanks people
    Steve Wargo replied 20 years, 7 months ago 3 Members · 5 Replies
  • Noah Kadner
    December 22, 2005 at 6:45 pm
    Are you in the U.S. or someplace else? There is indeed a PAL version of the B. The main difference is frame rates- you get 25p and 50i vs. 24p, 30p and 60i that the NTSC version does.
    Noah
  • Steve Wargo
    December 22, 2005 at 7:10 pm
    They sell hendreds of them in New York City in every street corner camera store.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
  • Englishman
    December 30, 2005 at 3:00 pm
    I live in England
    does the fact that it records at 25fps effect the picture quality through the editing process and beyond?
    thanks…
  • Noah Kadner
    January 4, 2006 at 8:35 am
    In what way? 25p is recorded to 50i tape so it will be compatible with any standard PAL TV or monitor the same way 24p is recorded into a 29.97 signal for the NTSC version of the camera(actually not the same way as 25p divides into 50i perfectly while 24p requires a 3:2 pulldown to go into 60i/29.97 NTSC). But that doesn’t matter much as far as final image goes- if you intend to show your work in PAL gear you need the PAL version of the camera and vice versa for NTSC.
    Noah
  • Steve Wargo
    February 4, 2006 at 2:12 am
    [englishman] “I live in England”
    Might have stated that in your first note, ey pardner.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
