Activity Forums Adobe After Effects can i assign a camera to a specific layer ?
  • can i assign a camera to a specific layer ?
    Posted by Anonymous on June 20, 2005 at 2:56 am
    I have about 6 layers in a comp and one uses 3d stroke. I’d like 3d stroke to be controlled by a comp camera, however the other 5 layers are also controlled by a camera and I want the stroke layer to be controlled independ of the other 5 layers. Is there a way to assign a camera to a layer.
    I would just use precomps but the 3d stroke interacts with the other layers and if i precomped it means I’d have to do some extra masking to get the stroke to convincingly interactive with the other elements.
    Mylenium replied 21 years, 2 months ago 2 Members · 1 Reply
  • Mylenium
    June 20, 2005 at 4:50 am
    For the most part: No. But you could try to make your other five layers into one layer by pre-comping and then use auto-orient or expresssions to make it stay in place even though your camera is moving.
    Mylenium
    [Pour Myl
