Activity Forums Adobe After Effects Can I apply Sketch & Toon effect to a 3D model using Element 3D in AE?
  • Can I apply Sketch & Toon effect to a 3D model using Element 3D in AE?
    Posted by Scott Green on June 26, 2013 at 8:46 am
    I’ve only recently started exploring Element 3D but I have a project that I’ve been working on in C4D using the Sketch & Toon effect.
    I was planning to bring footage of my rendered objects into AE and work on them that way but I’m wondering if Element would work better for me. I’m just not sure whether I can get the Sketch & Toon look to my objects in AE using Element. Is it possible?
    Here is a post that shows what I’ve been working on and the look I’m hoping to achieve:
    https://forums.creativecow.net/thread/19/881833
    Many thanks.
    Creative Multimedia Design Manchester | S©tt Green | Splurj
    Darby Edelen replied 13 years, 2 months ago 2 Members · 1 Reply
  • Darby Edelen
    June 26, 2013 at 2:10 pm
    Sketch & Toon in Cinema 4D has a very specific set of rendering parameters and capabilities that are not mirrored exactly by any other software I’m aware of. Element 3D renders using OpenGL and is much more limited in scope.
    So the short answer is: no.
    The longer answer is that if you work at it in After Effects you can use effects to create your own Sketch & Toon look to be applied after Element 3D. It won’t be the same and it will still be much more limited than C4D’s Sketch & Toon but it may work for you in this case.
    Darby Edelen
