Activity › Forums › Maxon Cinema 4D › can i add a visual 3d effect on an .avi in cinema 4d?
  • can i add a visual 3d effect on an .avi in cinema 4d?
    Posted by Sebastian Plamadeala on July 24, 2005 at 10:40 pm
    for example, a lightsaber effect on a broomstick…..
    i heard that one could use the “green backround” tehnique to add the 3d effect only on the green colored elements in the video. is this true? i really a good, video editing software with good video effects.
    thank you in advance,
    sebastian
    Chris Smith replied 21 years, 2 months ago 2 Members · 1 Reply
  • Chris Smith
    July 25, 2005 at 12:23 am
    Lightsabers are best done in a compositor using roto. It’s possible you can make a green stick that is well lit to try and get a mask without roto, but where it motion blurs may be a tricky key. See the post me that Filip and I wrote you in the AE cow.
    C4D and other 3D software are not built to do greenscreen. I’m not saying it’s impossible, but it is not what you want. It’s like cutting meat with a spoon.
    Chris Smith
    https://www.sugarfilmproduction.com
