Activity Forums Adobe Premiere Pro Can I add a description to clips in my project window?
  • Alex Udell
    October 28, 2010 at 4:28 pm
    Hi Milton…
    certainly. The deafault screen layout in Premiere Pro may not expose this column in the project panel.
    So spending a bit of time optimizing the panel sizes might help.
    here is a link to some info about customizing the layout of PPro: ://tinyurl.com/26ajtzh
    Additionally, the columns in the project panel can be rearranged so that you can see your information by your preferred order of relevance (left to right) in the project panel.
    Here is a bit of info on the project panel and it’s columns: ://tinyurl.com/27yamrx
    Once you get things organized in as you like, you can also save a custom layout so that you can always pull this configuration up quickly.
    Here is info about saving and recall ing workspaces: ://tinyurl.com/26a8ycu
    Let me know if this helps or not.
    (you have to copy and add the http to the above links…so the COW filter wouldn’t kick them out automatically)
    Alex
  • Alex Udell
    October 28, 2010 at 4:29 pm
    Hi Milton…
    here is a link to some info about customizing the layout of PPro: ://tinyurl(dot)com/26ajtzh
    Here is a bit of info on the project panel and it’s columns: ://tinyurl(dot)com/27yamrx
    Here is info about saving and recall ing workspaces: ://tinyurl(dot)com/26a8ycu
    Alex
