Activity Forums Apple Final Cut Pro Legacy Can FCS export to MPEG 2 Program type file?
  • Arnie Schlissel
    August 12, 2005 at 4:26 pm
    Not in one step. You can make the elemental mpeg & audio streams with Compressor, but then you have to find some 3rd party software to multiplex the 2 streams together.
    Arnie
    https://www.arniepix.com
  • Michael Alberts
    August 12, 2005 at 5:12 pm
    Actually, with Compressor 2 you can now do this in one step. You need to change the preset for your favorite MPEG 2 preset to “Multilexed MPEG-1/Layer 2 Audio”. This checkbox is found under the Encoder settings/Extras.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Arnie Schlissel
    August 12, 2005 at 5:18 pm
    I didn’t know that! That’s quite cool!
    Arnie
  • Master C
    August 12, 2005 at 8:25 pm
    I tried that setting, all I got was a video file with no audio.
  • Michael Alberts
    August 12, 2005 at 9:11 pm
    If you can’t get Compressor 2 to do it than you can always use BItVice Helper to mux the two files together. It’s free. http://www.versiontracker.com
    Michael Alberts
  • Charles Simonson
    August 15, 2005 at 7:23 pm
    Did you encode the audio as AC-3? QT cannot play back AC-3 audio, so when you play a MPEG-2 movie that is muxed with an AC-3 track, then you will not hear the audio, but it is there.
