Activity Forums Apple Final Cut Pro Legacy Can FCP Upres DVCPro50 MXF to HD?
  • Jeremy Garchow
    April 28, 2006 at 6:58 am
    Sure, but your results may vary.
  • Shane Ross
    April 28, 2006 at 7:11 am
    FCP cannot access MXF files for uprez natively. They will need to be imported into FCP first via FILE>IMPORT>PANASONIC P2. Then you can downconvert using the media manager and retain all the timecode.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Chris Baldwin
    April 28, 2006 at 7:18 am
    I want to upres Dvcpro50 mxf shot on the SPX800 and edited with 720p footage from a HVX200 and the output a HD Dvd on a 9 gig disk. many shooters tell me they shot with the SDX900 and upres it to cut with a Varicam. If a SPX800 has a HD lens on it shouldn’t it stand up pretty well to the HDX200?
    Chris Baldwin
    Shoulder High Productions
    Media of the World; For the World!
    https://www.shoulderhigh.com
    newsletters@shoulderhigh.com
  • David Roth weiss
    April 28, 2006 at 7:19 am
    [Shane Ross] “Then you can downconvert using the media manager and retain all the timecode.”
    Shane,
    I think that would be an upconvert.
  • Chris Baldwin
    April 28, 2006 at 7:31 am
    Is the import process a generation loss or signal degradation or just an unwrapping of the mxf to a quicktime file? but regardless as to the original question will the upres occur in final cut or compressor? this question refers to wanting to edit HD from a HVX200 and SD from a SPX800 and output a 720p DVD.
    Chris Baldwin
  • Matt Larson
    April 28, 2006 at 8:46 pm
    There is no generation loss, you are just doing a file transfer, and technically wrapping the MXF in a Quicktime wrapper.
    Your best bet is to run all of your DVCPRO 50 clips through Compressor using an Advanced Outputs preset (or something like that). There is a preset for DVCProHD which is what you are going to edit with, right? Just apply that preset and it’ll uprez-away.
    And if you do plan on doing this again, make a compressor droplet
