Activity › Forums › Apple Final Cut Pro Legacy › Can FC Express act as digitizing station for FCP?
  • Can FC Express act as digitizing station for FCP?
    Posted by Herb Sevush on July 20, 2006 at 1:53 pm
    (This message is cross posted in the Final Cut Express Forum)
    I need a secondary digitizing station for my FCP-HD system, and as I don’t need all the extras of Final Cut Studio, nor the expense, I was thinking that a simple FC Express setup, networked to my main FCP G5 would be a good idea. My question is — am I right?
    I need to ingest both DVCAM and DVCPRO 50 natively. I would like, but it wouldn’t be a deal breaker, to assign camera angles during capture because I do a lot of multi-camera work. I would capture the files to my FCP fibre channel drives, and then open the project file up in FCP when ready to start cutting. I would also need the ability to export in the codecs I use with FCP: DV, DVCPRO50, Uncompressed, MPEG2, Windows (with flip for Mac.)
    Is this possible and what would be the minimum hardware requirements to run Express for this purpose — could I get away with a Mac Mini for example, or would an older G4 be the way to go.
    Herb Sevush
    Zebra Productions
    Kevin Monahan replied 20 years, 2 months ago 7 Members · 6 Replies
  • Chris Poisson
    July 20, 2006 at 2:12 pm
    Herb,
    I don’t see why it wouldn’t, but you should also take a look at BTVpro, It’s a great little capture app, does killer adjustable time-lapse and still capture as well as motion. And its CHEAP!
    I believe it’s at bensoftware.com
    Have a wonderful day.
  • Walter Biscardi
    July 20, 2006 at 2:21 pm
    Unless it’s changed, FC Express was DV only. Not sure if they’ve added DVCPro 50 support.
    Walter Biscardi, Jr.
  • Bret Williams
    July 20, 2006 at 3:30 pm
    Does it support TC now? It didn’t originally. So sure you could capture a clip, but I thought it didn’t capture TC info – for that sole purpose of keeping it from being a rough cut or capture solution.
  • 13 Create COW Profile Image
    13
    July 20, 2006 at 3:39 pm
    I knew they have added HDV support in FC Express, but I dont think it can do DVCPRO
  • Jerry Hofmann
    July 20, 2006 at 4:03 pm
    It’s DV and HDV only…
    Jerry
  • Kevin Monahan
    July 21, 2006 at 2:34 pm
    Sure wish it supported at least one offline codec: OLRT would be fine.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
