Activity Forums Adobe Premiere Pro Can effects be applied to clip with straight alpha?
  • Can effects be applied to clip with straight alpha?
    Posted by Toke on May 7, 2008 at 2:48 pm
    When I try this I just get white clip.
    I don’t want to use premultiplied alpha because it messes semitransparent areas to black.
    Is there a workaround or should I just forget alpha with pPro?
    Toke replied 18 years, 4 months ago 2 Members · 3 Replies
  • Randy Mcwilson
    May 8, 2008 at 9:43 pm
    Can you give us more info? Your post did not seem complete.
    I use alpha channeled footage in PPro all of the time, no real problems.
    Eternity…don’t miss it for the world.
  • Toke
    May 8, 2008 at 10:28 pm
    Found a solution.
    Problem was that I was using 10-bit RGB codecs (SheerVideo & AJA) and pPro doesn’t seem to like them. Straight alpha with SV’s 10bit4:2:2 seems to be ok…
  • Toke
    May 8, 2008 at 11:28 pm
    Seems to be that pPro (I’m on a Mac) doesn’t either support any 10-bit YCbCr codecs neither…
