Activity › Forums › Adobe After Effects Expressions › Can check if a word exceeds the paragraph width?
  • Can check if a word exceeds the paragraph width?
    Posted by Andrei Popa on January 28, 2020 at 9:24 am
    I am trying to create a template that uses some paragraph texts.
    If I get the case that some word is too long and has to be broken, I would like to make the font smaller so it fits.
    Does anyone know if I can check if a word exceeds the paragraph width by expressions?
    Andrei
    My Envato portfolio.
    Andrei Popa replied 6 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 28, 2020 at 7:50 pm
    The only thing I can think of would be a hack, but it might be useful. You could have a source text expression like this:
    if (time < 0)
    “your_extra_long_word_goes_here”
    else
    value;
    Then you could use sourceRectAtTime() with a negative time to get the width of just that word. Then I’m not sure what you do, but hopefully that’s useful…
    Dan
  • Andrei Popa
    January 29, 2020 at 8:03 am
    I think I was not clear enough, but you gave me an idea anyway.
    I had a boxText paragraph that had a pretty small width. I was afraid that some words the client may use may overextend and be broken in half.
    I ended up creating an invisible text layer that had as value the longest word from the boxText.
    I then created a ratio variable that was botTextWidth/longestWordWidth. And i multiplicated the font size with this ratio if it were smaller than 1.
    Thank for the hint.
    Andrei
