Can Audio Master Channel of a MultiCam Sequence be Config’ed for MultiChannel in CS6
I have a 3 camera recording of a panel of 5 speakers. Each speaker was recorded on their own mic external to the video cameras.
I have synchronized the video and audio recordings via clapper visuals and audio sounds.
I want to edit the video using the MultiCamera sequence technique.
Then I want to export the resulting audio to Audition and clean up each audio track and then mix down to stereo output.Creating a MultiCam Source sequence only generates an audio 2 track master. This makes cleaning up the audio impossible.
Is there a way to configure the Source and probably the Target sequences to have the master channel configured as multichannel to keep the original 5 audio tracks separated?
Thank you for any assistance.
