Can any 2 drives in a array of 4 drives and loose no data
OK, I found out something and it gave me a warm feeling inside but thought I would check here if I am correct.
I have been told that is I have a RAID 10 (striped/mirrored/parity) array of 4 drives is ANY 2 of the drives fail the I will not loose data.
If I was simply using RAID 1 for 4 drives I basically have 2 mirrored pairs so if 2 drives go in the same pair I loose data.
I guess its the parity that makes the difference. In RAID 5 parity means I get 2/3 of the storage (rather than 1/2 for mirroring). With RAID 10, if my understanding is correct, I still only get 1/2 storage but ANY2 can fail (there are no mirrored pairs as such).
In this case (for 4 drives) RAID 10 is more secure than RAID 1.
Ben
Ben Edwards – Freelance Filmmaker
https://www.funkytwig.com
