Activity Forums Apple Final Cut Pro Legacy Can AJA KONA can output HDV sequence to HDCAM deck via HD-SDI?
  • Can AJA KONA can output HDV sequence to HDCAM deck via HD-SDI?
    Posted by Kozo Okumura on August 2, 2007 at 4:35 pm
    Can AJA KONA can output HDV sequence to HDCAM or any othe HD format deck with HD-SDI in via HD-SDI
    so that I can avoid the nightmare of outputting via firewire as it is.
    and any issue of doing that?
    thank you.
    David Roth weiss replied 19 years, 1 month ago 2 Members · 1 Reply
  • David Roth weiss
    August 2, 2007 at 5:32 pm
    Don’t know which Kona card you have, but the answer is most likely yes, absolutely. You’ll need to set your Kona Control Panel to output SDI 1080i — pretty much a peice of cake.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
