Activity › Forums › AJA Video Systems › Can AJA Kona 2 take DV footage and….
Posted by Scott Dominick on May 3, 2005 at 10:48 pmQuestion for the gurus…
Can the AJA Kona 2 take DV media and output it as AJA 8bit or 10bit media in an AJA based timeline?
The answer to this question is a determining factor in our facilities definite migration from the Pinnacle CineWave workflow.
Thank you,
Scott DominickWalter Biscardi replied 21 years, 4 months ago 4 Members · 4 Replies -
Walter Biscardi
May 4, 2005 at 1:20 amYou can set up a DV timeline and have it play out in realtime via the Kona 2 card, but it’s still DV footage. So you can simply edit a DV project, then play it out directly via SDI, Component or Composite to the deck of your choice.
Kona 2 is an excellent choice to migrate from CineWave. I did it last year and it’s just a killer unit with added benefit of 10bit HD built on-board instead of having to purchase the extra BOB and being limited to 8bit HD.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Ned Soltz
May 4, 2005 at 12:59 pmLet me add to Walter’s comments that I just migrated a client from 2 Cinewaves to 2 Kona 2’s and they could not be more delighted. Since the Cinewave has dropped in value so much, he intends keeping them and throwing them into some older G5’s just to capture the occasional 8-bit uncompressed SD from BetaSP. But they had so many problems with HD that their only option was to ditch them.
Ned Soltz
Walter Biscardi
May 5, 2005 at 2:08 am[Robert plant] “Good luck on the movie WALTER”
Thanks Robert! Actually had another planning session today. We shoot in two weeks with forum host, Clay Walker, as our Director of Photography. Really looking forward to it!
