Activity Forums Apple Final Cut Pro Legacy Can a video clip lose quality with ,multiple rerendering, with overall quality be sacrificed?
  • Can a video clip lose quality with ,multiple rerendering, with overall quality be sacrificed?
    Posted by Sebastian Knight on December 27, 2005 at 2:33 pm
    I have a question, can rerender a video file, say I rendered and found I forgot to add chapter markers to sequence, rendered it to a Quicktime DV clip, I deleted all render files after export. Now all I have is the DV clip that needs to have chapter markers added, When I open it in FCP 5, and add chapter markers and then export to a new updated Quicktime DV movie. Will I be sacrificing the quality of the this DV clip, if I now go in yet again, and add some Motion graphics, to it? Once again all render files are deleted. I guess what I am asking is if you open edit, several times using new render files each time you make changes with this compromise the quality of the final video?
    As always thanks in advance for your reply to my Post,
    Sebastian
    Peter Ralph replied 20 years, 8 months ago 5 Members · 4 Replies
  • Bouncing Account needs new email address
    December 27, 2005 at 2:35 pm
    [Sebastian] “I guess what I am asking is if you open edit, several times using new render files each time you make changes with this compromise the quality of the final video?”
    No.
  • Simon Webb
    December 27, 2005 at 5:44 pm
    I’m assuming you mean that you’ve exported the sequence to a QuickTime movie and then imported that movie back into FCP.
    Anyway, if that is what you’ve done, after you’ve added the chapter markers and the motion graphics, it’s probably best to export this new sequence as a QuickTime movie, making sure the “Make movie self contained” box is unchecked.
  • Bdr
    December 27, 2005 at 6:23 pm
    Chapter markers are contained in a Quicktime text track, not in the video stream itself. The video stream won’t change a bit if you use File > Export > Quicktime Movie (not Export > Using Quicktime Conversion). Off course, don’t tick the “Recompress All Frames” option.
    Adding motion graphics will cause rendering and recompression of all frames affected. This will compromise quality.
  • Peter Ralph
    December 27, 2005 at 11:47 pm
    you can also add chapter markers in DVDSP
