Activity Forums Apple Motion Can a SD motion template be converted to HD?
  • Can a SD motion template be converted to HD?
    Posted by David Hunter on August 12, 2008 at 8:14 pm
    I have a Motion template in SD aspect ratio I would like to use for my DVCPRO HD 960X720 project in Final Cut pro.
    I have Motion set for the DVCPRO HD preferences when starting a new project or in exporting video.
    Is there a way to reset all the aspect ratio values for this Motion template globally to convert it to one that I can customize for editing in the HD 960X720 aspect? I have project properties set for 960X720.
    I notice right now that I cannot even manually change the values on individual layers for such things as graphics from 70X576 dimensions. Of course, I can manually reset handles but this is sloppy. The provision for writing in the dimensions is greyed out.
    Is there a way to globally at least reset the width and height and save as a template copy suitable for tweaking in HD?
    Thank you!
    David Hunter replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
