Activity Forums Apple Final Cut Pro Legacy Can a SD DVD be 23.8 fps?
  • Can a SD DVD be 23.8 fps?
    Posted by Kevin Camin on March 22, 2011 at 6:04 pm
    Forgive my ignorance but I haven’t set up a DVD project for sometime.
    My project was shot on 24p and it needs to go to SD DVD. Can I retain that frame rate for SD DVD? And it is upper field first, right?
    Thanks.
    Kevin Camin replied 15 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    March 22, 2011 at 6:44 pm
    23.98 is a frame rate you can put on a DVD. And it is a progressive format…no field dominance.
    Shane
  • Kevin Camin
    March 28, 2011 at 6:55 am
    So a SD DVD can support 24p? This DVD is going to market and needs to be playable on all DVD players, even really old ones.
    Thanks.
    Best regards,
    Kevin Camin
