Activity Forums Adobe After Effects Can a “ram disc” allow longer ram previews?
  • Todd Kopriva
    June 17, 2009 at 3:06 pm
    No, not really.
    Keep in mind that the disk cache (which this doohickey seems that it might add to) only applies to standard preview (aka, spacebar play).
    The RAM cache (the part of RAM that RAM preview frames are stored in) is contained within the RAM allocated to the foreground process of the After Effects application. This is theoretically limited to 4GB; once you subtract the bite that the OS takes for its UI libraries and such, you’re left with about 3GB. And After Effects will only use a set percentage of that for the RAM cache (which ends up being about 2GB).
    Adding more RAM to your system will not increase RAM preview length, unless you had so little RAM that you weren’t able to give that 3+ GB to the foreground application.
    Adding more RAM to your system _will_ make it so that you can use the Render Multiple Frames Simultaneously multiprocessing feature without starving your processor cores of RAM.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Richie Tovell
    June 17, 2009 at 4:16 pm
    ah, I see.
    Oh well, loocks like my reacent switch to working in HD is going to require me to move back to 64 bit then, ok no probs.
    Thanks for clearing that up for me guys.
    Regards Richie.
