Activity Forums VEGAS Pro Can a mask be used to fade to tranparent?
  • Can a mask be used to fade to tranparent?
    Posted by Larry Cole on May 4, 2011 at 4:22 pm
    I’m using the chroma key effect to remove background from the person in my video. Unfortunately, I cut this person off at the knees so when I insert them infront of my beautiful field of grass, the hard edge gives the effect away. I’d like to soften the hard edge at their knees by a gradual fade to transparent.
    I’ve used gradient masks before but it seems I can only either have the image, black or somewhere in between. Is it possible to have the image, transparent and everything in between?
    Larry Cole replied 15 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    May 4, 2011 at 4:58 pm
    You can use the Mask in Pan/Crop to create a feathered edge at the bottom of the video. You can also add the Border FX with Soft Edge preset, or you can use a piece of black and white Gradient Generated Media on a track above and change the Track Composite Mode to Multiply (Mask). Any of those three should work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Larry Cole
    May 4, 2011 at 6:42 pm
    Figured it was something easy. Thanks.
