Activity › Forums › Apple Final Cut Pro Legacy › Can a FCP PC project port to MAC FCP ?
Posted by John Allen on June 28, 2011 at 11:31 pmI am wondering if FCP projects done on a PC can be read/imported to FCP mac.
thanks in advanceJohn Allen replied 15 years, 2 months ago 4 Members · 5 Replies -
Shane Ross
June 29, 2011 at 12:13 amInteresting…seeing that FCP doesn’t run on Windows. How is FCP running on a PC? Hackintosh? if so, then it is the MacOS, and the project file will open fine, as long as the FCP versions match.
The MacOS is the MacOS.
Shane
Read my blog, Little Frog in High Def -
Michael Gissing
June 29, 2011 at 12:13 amFinal Cut Pro is Mac only software, produced by Apple. There is no such thing as FCP projects on a PC. Windows or Linux based software cannot run FCP.
If you meant a Mac PowerPC, then the answer is yes. Up until FCP X old versions of FCP can be opened by newer versions on modern Macs.
John Allen
June 29, 2011 at 1:44 amsilly me…
I meant to post this in AE – the question is can an AE project on PC go to osx10.6 ?
any idea before I repost?
thanks again -
Rafael Amador
June 29, 2011 at 4:28 pmHi John,
AE projects should work in both platforms.
Just check versions compatibility.
rafael -
John Allen
July 1, 2011 at 7:17 pmI found out the easy way – I tried it, and it works. the project opens right up but I had to relink all the media manually.
Thanks y’all.
