Activity Forums Adobe Premiere Pro Camtasia in Premier
  • Camtasia in Premier
    Posted by Matt Hargrave on June 16, 2006 at 5:18 pm
    I have been working on a website walkthrough the past few days and have just encountered a major road block. When I brought the Camtasia AVIs into Premier they looked awful. As a test I exported a clip out of Premier into .aaf format and started an AfterEffects project with that. That made the video look fine. So I cut my entire project in Premier with the plan of bringing it into AfterEffects when I was done and rendering it out high-quality. Unfortunately you cannot bring transitions into AfterEffects. Now I am stuck recutting every transition in the entire piece. Does anyone know a way around this? Any help would be greatly appreciated.
    Tim Kolb replied 20 years, 2 months ago 4 Members · 3 Replies
  • Redgum
    June 16, 2006 at 10:44 pm
    What screen resolution did you use to capture with Camtasia? This often effects the quality of the AVI.
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
  • Aanarav Sareen
    June 18, 2006 at 2:38 am
    Couple of questions:
    1) What is your capture codec in Camtasia?
    2) What is the screen capture size?
    3) What are your Premiere Pro project settings?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Tim Kolb
    June 19, 2006 at 1:17 pm
    I have found that PPro handles Camtasia material excellently with the following caveats:
    1. Ignore the alpha channel (in AE as well)
    2. Set Premiere Pro’s project settings using the “desktop” heading in the “custom” section, then choose the TechSmith codec or uncompressed with the same frame size as the Camtasia capture…(often it is 1024×768 or some other res that is common for computer screens but not for video).
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
