Activity Forums Adobe After Effects CamStudio pipeline into After Effects CS4
  • CamStudio pipeline into After Effects CS4
    Posted by Jesse Skellington on July 10, 2010 at 6:44 am
    Hi All,
    I have found this CamStudio pipeline into After Effects CS4 to be working great so far. If anyone has other useful tip please jump right in 🙂
    Step 1
    The version I use is Camstudio is 2.0. (https://CamStudio.org)
    —* The codec was:
    —* “CamStudio Lossless Codec v1.4” or “ffdshow Video Codec”.
    The setting are:
    —* Set Key Frames Every: 120
    —* Capture Frames Every: 33
    —* Playback Rate: 30
    Step 2
    Then to convert the video I use “FLV to AVI MPEG WMV 3GP MP4 iPod” Converter it can be found here: (https://www.aone-soft.com//flv_to_avi_mpeg_wmv_3gp_mp4_ipod_converter.htm)
    —* The version I use is “FLV to AVI MPEG WMV 3GP MP4 iPod” Converter is 5.0.0526
    The settings are:
    —* Output Format: H264 – AVC MPEG-4 Format (*.mp4)
    —* Video Quality: Superb
    —* Video Size: Keep Original Size
    Step 3
    In After Effects CS4 I render out to:
    —* Format: QuickTime Movie (I use the defalts)
    —* Note: This will make a Large GB Sized file but this is how I keep the pixel quality perfect.
    Step 4
    Next I use Adobe Media Encoder CS4
    * Format: FLV | F4V
    * Preset: FLV – Web Large, NTSC Source (Flash 8 and Higher)
    Step 5
    —* Same settings
    After all this I keep the pixel quality high and the file size down.
    Cheers
    -=Jesse=-
    Jesse Skellington replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
