Activity Forums Compression Techniques Campark Action Cam footage not editable – what to convert to??
  • Campark Action Cam footage not editable – what to convert to??
    Posted by Adrian Nowski on July 16, 2017 at 1:02 pm
    Hi All,
    This is my first post on the forum.
    I am an amateur video editor. I have recently bought a 4K Action Cam – Campark. Footage from this camera in standard 1920×1080 edits in Vegas Pro without any problems. The 4K footage (it is actually 3840×2160) can’t be edited. On Vegas pro I get strange flickering on crossfades. Video below:
    https://www.youtube.com/watch?v=7VTrOxeO-y4
    I have also downloaded the latest trial edition of Adobe Premiere Pro to see if the problem is with Vegas or my footage. And I have issues in APP too. After adding videos to the timeline, video repeats frames or certain few seconds fragments randomly, which leads me to thinking that my 4K footage is in some strange format. Info from MediaInfo below. I thought of converting them to something else to be able to edit in Vegas, but Handbrake doesn’t open my footage. I get this message:
    “Handbrake will not be able to encode the selected source as it did not find the valid source with titles to encode. This is due to the following reasons:
    – The source file is not a valid video file or is a format that HandBrake does not support
    – The source may be copy protected or include DRM”
    Would you be able to suggest anything? Do I need a certain codec to be able to process this footage in Vegas Pro? These videos play OK in Windows though.
    MediaInfo:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/mp41)
    File size : 722 MiB
    Duration : 4 min 21 s
    Overall bit rate mode : Variable
    Overall bit rate : 23.1 Mb/s
    Tagged date : UTC 2017-06-18 15:41:14
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Source duration : 4 min 21 s
    Bit rate : 23.1 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.093
    Stream size : 720 MiB (100%)
    Source stream size : 720 MiB (100%)
    Language : English
    Color range : Limited
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    mdhd_Duration : 261797
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Bit rate mode : Variable
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 8 000 Hz
    Frame rate : 7.813 FPS (1024 spf)
    Compression mode : Lossy
    Source stream size : 555 KiB (0%)
    Language : English
    Hardware info:
    i7-6500U
    8GB RAM
    Intel HD Graphics 520 – integrated
    500GB HDD
    Adrian Nowski replied 9 years, 1 month ago 2 Members · 2 Replies
  • Craig Seeman
    July 20, 2017 at 11:48 am
    If Vegas and PPro show the same issue perhaps it’s something about decoding the GOP structure that’s at issue.
    Can you try converting it to DNxHR which is an iFrame codec?
  • Adrian Nowski
    July 23, 2017 at 11:07 am
    Re-wrapping in ffmpeg cured the issue
