Activity Forums Apple Final Cut Pro Legacy Camera tracking/following a person
  • Camera tracking/following a person
    Posted by Per Ottesen on January 10, 2007 at 8:07 pm
    It’s not a particular FCP question, but I don’t know where else to ask, so I’ll give it a try:
    I’m looking for a setup where a camera can follow a teacher, when he’s walking around up at the desk. I’m thinking of some kind of a transmitter/receiver, where a receiver on the camera can follow the transmitter, that are placed on the teacher, but I REALLY don’t know if that exist ????
    Hope that some of the participents of this forum can help 😉
    Per Ottesen replied 19 years, 7 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    January 10, 2007 at 8:21 pm
    Wirelessly controlled robotic camera systems probably cost more than raising a child to become a camera person. I’d do the latter first.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ben Insler
    January 10, 2007 at 9:00 pm
    …to answer your existence question, though, those rigs do exist. They have a tracker in hockey pucks so that the goal cameras can follow along without missing a frame. Large theater performances sometimes use the same technology with a tracker worn by an actor to perfectly control their follow spots. I think the important thing to notice though is that in these applications precision is key. I don’t know if anyone could flawlessly follow a hockey puck that instantly starts moving at 80 miles an hour across a rink even once, much less every time it’s shot. In theater, this type of rig can ensure precise lighting queues 2 times a day, 4 days a week, for years. I’m not sure that you need this type of precision, especially given the cost, as Jerry noted, unless your application is much more extreme than your example.
    Best,
    Ben
  • David Roth weiss
    January 10, 2007 at 9:14 pm
    I have seen inexpenive versions of radio directed mounts that couple to cameras mounted on standard professional fluidhead tripods. Check online at Markertek and B&H, I believe you will find them there.
    DRW
  • Per Ottesen
    January 11, 2007 at 2:41 pm
    Thank’s.
    I’ve give it a try both at Markertek and B&H, but I can’t find the cheap solution (it can be there, and just me there can’t find it), because since it’s a teaching situation there aren’t money to pay for a “big” pro-installation.
