Activity Forums Adobe After Effects Camera Tracker Error and Square Pixels
  • Camera Tracker Error and Square Pixels
    Posted by Julie Dehaan on August 31, 2015 at 12:10 am
    Okay, I made a comp with an mpeg (1440×1080, 1.33) , and it looked squished, so I changed the comp settings to 1920×1080, square pixels. BUT then when I tried to use the camera trackers it gave me the error “3d Camer tracker: Layer size must match composition and use default transform values.” Problem is, I can’t match the layer to the comp otherwise its squishesd. How do i fix this?
    Kalleheikki Kannisto replied 11 years ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 31, 2015 at 10:59 am
    Depends on your delivery requirements. If you need to output 1440×1080, turn on the pixel aspect preview and use the original dimension file. If you want the final at 1920×1080, you can precompose the scaled layer and 3D camera track the precomp.
