Activity › Forums › Maxon Cinema 4D › Camera Target “Can’t render the camera movement.”
  • Camera Target “Can’t render the camera movement.”
    Posted by Sergevc on April 19, 2007 at 8:26 am
    Hello,
    I seem to have a problem with the camera. I made a 3D folder, and arranged is that it opens. To make it more spectacular I added a camera that travels around this folder.
    Her comes the problem; When I render this I only get an animated folder, and no camera movement. I allready tried to adjust the Align to spline tag but nothing happens.
    Can anybody help me. I am fairy new to Cinema 4D and I could use some help.
    ( Podcast link are also welcome.)
    Thanks in advance.
    Serge
    More fools than tools! Starting with me!
    Brian Jones replied 19 years, 5 months ago 2 Members · 3 Replies
  • Brian Jones
    April 19, 2007 at 2:01 pm
    Are you rendering using the Camera that’s moving or the Editor Camera?
  • Sergevc
    April 19, 2007 at 4:21 pm
    Good question!
    How do I know wich camera is rendering?
  • Brian Jones
    April 19, 2007 at 6:46 pm
    go to the Cameras menu (on the view window not the main menus on the very top). In there is Scene Cameras (if you have more than one camera whichever is checked is used for render) and third in the list is Editor Camera. If the camera in Scene Cameras is checked it should render from it by default. If it does not there is, however, another control in the Edit menu (to the left of the Cameras menu) which can also affect things, ‘Use as Render View’. If you check off the camera you want to render from then make sure Use as Render View is checked for that camera then you can edit using the editor camera or whatever then when you do a render it will use whatever you set up as the ‘Use as Render View’ and you don’t have to frame it up to render.
