Activity Forums Adobe After Effects Camera programming
  • Camera programming
    Posted by James St clair on April 4, 2011 at 8:42 am
    Hi AE,
    I’m programming the camera (all layers in comp are 3D) to zoom in and incorporate also some x and y movement. What I find happening is, I will zoom the camera IN to a point in say 3 secs, 0 frames. Then I set another keyframe 2 secs later at frame 5;00 to begin a zoom OUT. Then in frame 7;00 I pull the camera OUT to a diff point.
    That movement should look like: camera zooms in, stops at frame 3;00, stays still until frame 5;00, then zooms out until frame 7;00
    What I get is what looks like momentum of the camera. During frames between 3;00 and 5;00 the camera moves in slightly until fr 4;00 and THEN moves out again to where it was at frame 3;00 when it reaches frame 5;00. Those frames should have NO movement, yet the camera is moving when I have not programmed it. Why is that happening, the camera should only be reflecting movement that I have programmed into the keyframes. Where is this extrapolation of movement coming from?
    thanks
    JSC
    James St clair replied 15 years, 5 months ago 3 Members · 3 Replies
