Camera Parented to Null Problem – Timeremap causes a blur
I have a simple scene involving 2 moving objects. I have created a Null that uses the same position properties as Object 1, then parented a camera to the Null. In effect my camera moves at the same speed as both Object 1 and the Null. This works fine (Object 1 is in focus as it is moving at the same speed as Camera) … until I add a time remap or freeze frame to Object 1 – after which Object 1 becomes blurred (this is what I cannot understand). Object 1 is a precomp and has no animation inside it. I would like to keep it this way.
I have attached an AE file and the top layers can be toggled to see the difference between NO timeremap and TimeRemap/FreezeFrame on Object 1.
https://f1.creativecow.net/4495/camera-tracking
Any help would be appreciated. Thank you.
Matt Greig
London England
