Activity Forums Apple Final Cut Pro Legacy camera not syncing with FCP
  • camera not syncing with FCP
    Posted by Courtney Olender on May 16, 2010 at 8:28 pm
    I have a Sony Handycam HDR-SR11 Camcorder
    and I’m trying to transfer footage into final cut pro.
    I have watched countless videos online on how to log and transfer. The problem is in all of these videos the camera automatically syncs with final cut… my camera will not do this.
    any suggestions?
    Courtney Olender replied 16 years, 4 months ago 5 Members · 6 Replies
  • John Fishback
    May 16, 2010 at 10:46 pm
    I don’t know that camera, but many require a menu setting to enable Firewire or USB or, perhaps, go into VCR mode. Just a thought.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Michael Gissing
    May 17, 2010 at 1:04 am
    How are you connecting the camera to your Mac? Can you see the cameras files in a folder in the finder? Not sure what you mean by syncing? Are you trying to control the device like a VTR or transfer files off?
    If you mean VTR control is not an automatic process but requires both FCP to be set to the correct Easy Setup and the camera also to have the correct menu settings.
  • Michael Gissing
    May 17, 2010 at 1:13 am
    Just had a look at the camera specs online and it says mpeg2 as the record format. If that means it is mts or an mpeg2 tranaport stream, then yo8u may need software other than log & transfer which is designed to import AVCHD and XDCam.
    First things first, though, can you see the camera and files in finder and if so what does getting info tell you about the files.
    If it is .mts then try a forum search as converting these files has been covered here many times.
  • Zane Barker
    May 17, 2010 at 6:29 am
    What version of FCP are you using?
    Hindsight is always 1080p
  • Joseph Holder
    May 18, 2010 at 3:10 am
    well, I know that when I tried to export with my camera, it wouldn’t show any thing.. so I looked some stuff up and found out you have to turn your airport off for some odd reason… but try this and let me know
  • Courtney Olender
    May 18, 2010 at 5:03 pm
    hmmm… I’ll keep that in mind for the future but no luck with it this time.
    Thanks for the suggestion.
