Activity Forums Adobe After Effects Camera Moves
  • Camera Moves
    Posted by Gregory Kuhn on February 14, 2008 at 6:00 pm
    I am working with a virtual background and I am wanting to do a camera pull from a monitor to the full set where my talent is standing. Pretty simple move really. But for the life of me, I cannot get the camera to move on the x and y axis. It pivots instead of actually moving the camera left to right. Can anyone tell me how to have my camera actually move from left to right instead of pivoting?
    Greg Kuhn
    Proverbs 15:22
    Without counsel, plans are frustrated, But with many counselors they succeed.
    David Franklin replied 18 years, 6 months ago 4 Members · 3 Replies
  • Ej Hassenfratz
    February 14, 2008 at 6:41 pm
    Create a Null layer, and search in the effects panel “Seperate XYZ” and apply it to the null. Now parent the Camera layer to the Null layer and use the X Y Z sliders applied to the Null layer.
    ej.hassenfratz
    senior.graphic.designer
    wjla-nc8/eyedesyn.com
    washington.dc
  • Steve Roberts
    February 14, 2008 at 7:59 pm
    Or … select the camera, then layer>transform>auto-orient>off.
  • David Franklin
    February 14, 2008 at 9:42 pm
    Or use the camera tool.
    To do this, turn on the stopwatch for BOTH camera position and point of interest and make start keyframes. Make sure all your layers are set to 3D (otherwise the camera won’t apply to them).
    Then move down in the timeline, and hit the c key to use the camera tool. As you toggle through the options by repeatedly hitting the c key, you will be able to pull back, push in, move in the x-y axes, or rotate the orientation of the camera. As long as you’ve turned on the stopwatch, any move you make will automatically create new keyframes in the timeline.
