Activity › Forums › Adobe After Effects › camera movements effecting entire comp
  • camera movements effecting entire comp
    Posted by Colin Kennedy on March 29, 2012 at 4:51 pm
    I am setting the keyframes at the current position, before I make any camera movements, then I make a camera movement, and it throws off the camera position in the comp before I made the movement. Does anyone know why this might happen? Im sure its an easy fix. Thanks- Colin
    Darby Edelen replied 14 years, 6 months ago 2 Members · 1 Reply
  • Darby Edelen
    March 29, 2012 at 6:39 pm
    I’m not quite sure what you’re describing.
    You’re setting keyframes at some time, moving down the timeline and then adjusting the camera position? That should work fine.
    Can you describe the way the camera movement is misbehaving in more detail?
    Darby Edelen
