Activity › Forums › Maxon Cinema 4D › Camera move on beat
  • Camera move on beat
    Posted by Syed Iqbal on April 2, 2017 at 8:52 pm
    Hi everyone,
    Can you please help me understanding following 2 effects:
    1)
    At 1:16 as an example, you will see in following clip that camera or objects movement is matching to sound beat. I want to know if this could be possible to use sound effector to achieve this kind of camera movement.
    Example clip: https://www.youtube.com/watch?v=yBrC9Xrlzk8
    2)
    In a different clip https://www.youtube.com/watch?v=lg_kW8lWnA8 you see that 3d text at 28 seconds gets displaced synced to a surrounding shockwave object. I would like to know the trick to get this kind of effect.
    Thanks.
    Syed
    Syed Iqbal replied 9 years, 5 months ago 2 Members · 2 Replies
  • Corrado Carlevaro
    April 18, 2017 at 10:49 am
    If you use an Xpresso Sample node connected to a Sound Effector you can drive any property using the “strength” output of said Sample node.
    Sound Effector -> Sample Node->Range mapper-> Camera Z position (whatever).
    In the second examples the displacement happens only once so it can be done manually
    Corrado
  • Syed Iqbal
    April 18, 2017 at 1:04 pm
    Thanks a lot Sir. Much appreciated.
