Activity › Forums › Adobe After Effects › Camera move and HD to SD downconvert
  • Camera move and HD to SD downconvert
    Posted by Post:blur on October 30, 2006 at 2:46 am
    So I have created my project at a 1920×1080 aspect ratio… I can nest this project in a SD (720×486) composition letterboxed/fitted to screen and it looks good. -BUT- When I do a camera move in the HD version (to make a pan/scan version) the camera move is not in the nested version. My workaround is to render the HD file and inport that into a SD comp… any shortcut or trick to nest it instead?
    Post:blur replied 19 years, 11 months ago 2 Members · 2 Replies
  • Mylenium
    October 30, 2006 at 3:21 pm
    Are you using continuously rasterize on the nested comp? This will disable nested cameras, so if you can do not use it.
    Mylenium
    [Pour Myl
  • Post:blur
    October 31, 2006 at 12:07 am
    Nope, the images are large format pictures, so there is no rasterizing.
