Camera motion
Hi everybody!
I’m planning to do a short video (around 30′) where a camera moves along the scene “visiting” different parts of the animation. I have left you three captures. The first one is the whole scene, where the camera will move. Then, the second and the third one is the appearance that should have the animation. The arrows show the camera motion. It supposed, that every single element will have its own animation. I’m quite sure you’ve seen this effect in many places , the problem is that I don’t know the name.
https://www.alu.ua.es/j/jlqb/Pruebas.jpg
https://www.alu.ua.es/j/jlqb/Pruebas2.jpg
https://www.alu.ua.es/j/jlqb/Pruebas3.jpgMy question is about the composition of all the elements and the workflow I should follow. Should I make a big video (around 1200×950) and move up and down the camera? What about leave the camera stationary and move the whole composition? Is there any way to make the composition in small videos and then put them together when everything is done?
Thanks in advance
Jose.
