Activity Forums Adobe After Effects Camera invert itself. What to do?
  • Camera invert itself. What to do?
    Posted by Giacomo Tventi on August 9, 2014 at 3:58 pm
    Hi, i’m new to the forum.
    For the past years i’ve been dealing with a tedious problem: it seems that, if i orbit an after effect camera on its vertical axis, getting a “Top view” of the object, when i past this limit, it ivert itself, meaning that it shows a “mirrored” version” (interted perspective)of the same point of view.
    I’ve reinstalled AE multiple times and serched for this issue all over the internet, without success. I hope some of you can help me out. Now, in particular, that i discovered Element 3d, this is really becoming annoying.
    Thank in advance for any response.
    Bye! 🙂
    Giacomo Tventi replied 12 years, 1 month ago 3 Members · 3 Replies
  • Brian Charles
    August 9, 2014 at 4:27 pm
    The camera is a 2 node camera, both Position and Point of Interest ( the 2-nodes) need to be animated.
    When the Camera crosses the Point of Interest the camera turns to face it.
    The solution is to either use a one node camera which only uses position (it’s found under camera options) OR to animate the Point of Interest as well as Position.
  • John Cuevas
    August 9, 2014 at 8:04 pm
    Here’s a link to a thread that has some links to some good camera tutorials and camera rig setups(makes controlling the camera easier)
    https://forums.creativecow.net/readpost/2/1031696
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Giacomo Tventi
    August 10, 2014 at 1:42 pm
    THANKS A LOT! I really wasn’t capable of figuring it out by myself. I learned AE by indirect tutorials, and i have never went in-depth with its capabilities. Maybe i’ll watch some tutorials regarding AE’s Camera. Thanks Again 🙂
