Activity › Forums › Maxon Cinema 4D › Camera doesn’t register wheels rotating issue
  • Camera doesn’t register wheels rotating issue
    Posted by Yasser Abdulghani Muhsen on December 29, 2023 at 4:43 pm
    Hello guys!
    I’ve found this site very helpful so I came to dead end about my issue.
    I’ve been done a Car rig character in Cinema 4D 2023 and everything works great. But!
    Some camera such being a children under a car body shows that the wheels do rotate in preview render. But if it is not being a children then it shows that wheels is “stuck”. So how do I fix the problem? I’m using Redshift for this.
    It’s a simple road, on a linear path. Set a spline from 0 % to 99 %.
    Kouraib Abdmalek replied 2 years, 9 months ago 2 Members · 1 Reply
  • Kouraib Abdmalek
    December 30, 2023 at 8:57 am
    Hi Yasser,
    We are glad to know that the forum is useful to you, thank you! About your issue, you should delete the animation track before making the camera not children, then re-record the path. If this does not work for you, please post the file here so we can check it.
    I hope this helps you.
