Activity › Forums › Adobe After Effects › Camera Depth of Field
Posted by Kumar Srimali on January 30, 2012 at 8:56 pmI am using depth of field in camera. I have placed images in layers and while enabling depth of field, it shows small white colored circles in some part of the pic (see attached link), how to get rid of it ?
Michael Szalapski replied 14 years, 7 months ago 4 Members · 6 Replies -
Paul Roper
January 30, 2012 at 9:10 pmNot exactly sure what’s causing this, but I’d guess it’s the highlight controls under the depth of field settings. Change them back to their defaults: Diffraction: 0, Gain: 0, Threshold: 255, Saturation 0.
Then, if you want the bright highlights-depth-of-field effect, GRADUALLY tweak these numbers to get the desired effect.
John Cuevas
January 31, 2012 at 3:30 pmIf that’s a PC project, if you post it(with a couple of the pictures) I’ll open it up it up and see if the same things happen.
Don’t want to say I’ll open up the Mac project files, because I’ve discovered that Mac/PC people have different problems. But most likely a Mac guy will come along and take a look also.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Paul Roper
January 31, 2012 at 6:04 pmGo to the camera in your timeline and open up the camera settings.
Paul Roper
January 31, 2012 at 6:06 pm…That’s assuming you’re using CS5 or later (or maybe it was introduced in CS5.5? I’m not sure). Those additional depth of field adjustments didn’t exist in earlier versions of After Effects.
Michael Szalapski
January 31, 2012 at 6:27 pmCheck out the possible solutions posted in this thread: https://forums.creativecow.net/thread/2/1013288
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
