Activity Forums Apple Final Cut Pro Legacy CAMERA COMPATIBILITY IDEA
  • CAMERA COMPATIBILITY IDEA
    Posted by Redford Givens on August 8, 2007 at 6:57 pm
    Read a couple of threads about FCP & camera capture problems.
    This is probably crazy, but suppose you take the DV Cassette from the incompatible camera put it into a compatible camera that uses the same cassttes and then capture to FCP.
    The question being can the compatible camera read the other camera’s codec and send it in its own format???
    Just thought I’d ask.
    Redford Givens replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
