Activity › Forums › Adobe After Effects › Camera blur map / depth map showing as a solid white square on black
  • Camera blur map / depth map showing as a solid white square on black
    Posted by Samantha Derochie on April 21, 2016 at 10:02 pm
    I was trying to use the frischluft lenscare plug in, but when I select a layer to use as a depth map, it just ignores the map and blurs only a rectangle in the center of the frame at full and everything else at none. When I show the depth buffer, it show a white rectangle on black, instead of the grayscale ramp I have on my depth map layer. The same thing happens when I try and use AE’s built in camera lens blur effect. I feel like I’m missing something very obvious here, but I can’t seem to figure it out.
    Thanks for your time!
    Tudor “ted” jelescu replied 10 years, 5 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    April 22, 2016 at 6:47 am
    Post a screen grab of your layer setup, the comp window and your depth map.
    Tudor “Ted” Jelescu
    Senior VFX Artist
