Camera and File Type Settings for Optimal Import into FCP 7
Greetings! I’ve had a project sprung on my at work: I have been asked to edit what will be a simple training video, components of which are to be recorded in Greece, but I am located in the USA (and they will not fly me out there to record in person…
The Powers that Be have asked me for specifications on how the Greek folks should set up the camera in the recording room, so that the files will be easy for me to edit on my end. Ack! Eek! Nooooo!
I have never done this sort of, ahem, workflow. I’ve always been present to set up the camera, then I log and capture from either tape or upload the files from Flash memory. What should I tell them? I don’t want to end up with some weird format that is un-editable/uses some diabolical codex from hell…HELP!
I’m looking for simple camera settings and then what file type they should convert/save as once they are done recording the subjects.
Thank you so much!
KB
(The Graphic Designer with Basic Video Skeelz Who’s Been Drafted).
