Activity › Forums › Blackmagic Design › Calibrating my JVC DT-V1710CG
  • Calibrating my JVC DT-V1710CG
    Posted by Christian Mathis on September 20, 2012 at 11:19 pm
    Hey everyone
    I have the monitor over a year now and I calibrated it alway doing it with blue only. But I guess this is not too accurate for a precise color grading.
    I have a 8Core Mac and a BlackMagic Intensity Card and connect the Monitor over component cables.
    For the TFTs I use a Xrite iDisplayPro.
    Is there a way to send may main monitor image to the external over the BM-Card?
    Or go over a VGA-Component to the CTR?
    JVC send me this link for the calibration of there TFTs:
    https://www.service.jvcpro.eu/public/document.cfm?prog=SupSoft.cfm&Model=DT-V24G1E
    Has someone experience with calibrating the JVC CTR?
    I just feel like that my monitor is a bit off. I just want to make sure everything I see is what I export.
    Thanks a lot for your help
    Christian
    Christian Mathis replied 13 years, 12 months ago 1 Member · 1 Reply
  • Christian Mathis
    October 5, 2012 at 12:38 am
    what I did I tricked my iOne Display and downloaded some charts from the web. With the grayscale.
    With drive and cut off you can adjust the WB. Drive for the Highlights and cuf off for the dark parts.
    With the iOne I also set the cd/m² (Brightness) and then at the end I did the blue only.
    https://www.homecinema-fr.com/colorimetre-hcfr/hcfr-colormeter/
    is a great link!!
    Good colors
