Activity Forums Adobe Photoshop Calibrating iMac with X-rite i1 Display 2 colorimeter
  • Calibrating iMac with X-rite i1 Display 2 colorimeter
    Posted by Kevin Camin on November 20, 2011 at 1:03 am
    I’m placing this question here because undoubtedly some working PS professionals will have dealt extensively with monitor calibration for the web.
    I am trying to properly calibrate my iMac i7 for web work. I do photographs and video for the web.
    I’m using the X-Rite software that came with the device. I’m dialing in the following settings in Advance Mode:
    D65
    130 cd/m2 (130 is my target, but I got it to 138 and I’m fine with it)
    Gamma 2.2
    I work in a moderately lit environment.
    1. Should this be a reliable profile for what I am trying to do? When I run the calibration software in easy mode I get what looks like a tiny, tiny green cast (but that could just be that my Advanced Mode profile has a tiny magenta cast, so I don’t know). Anyways they don’t match up.
    2. I chose 130 cd/m2 based off recommendations. But are those recommendations for printer accuracy? I know the iMac’s screens can get really bright, but a lot of monitors can. I’m going to the web with this work so is there a different standard for cd/m2 settings?
    Any thoughts or suggestions would be much appreciated.
    And again this is web work.
    Best regards,
    Kevin
    Best regards,
    Kevin Camin
    Kevin Camin replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
