Activity Forums Apple Final Cut Pro Legacy Calibrating crosshairs for mattes in FCP
  • Calibrating crosshairs for mattes in FCP
    Posted by Roman Bostick on June 11, 2009 at 6:23 pm
    When the crosshairs go off the screen and are not directly on the points/numbers in a matte – is there a way to calibrate them?
    Very difficult to matte something out when the crosshairs are not in line…
    Also, does anyone work with CHV Bezier Mattes plug-in that this happens with and how to fix them? May be an Apple glitch but really need to know a solution
    Roman Bostick replied 17 years, 2 months ago 3 Members · 4 Replies
  • Kevin Monahan
    June 11, 2009 at 8:53 pm
    If you scale an item before applying the matte or are using a clip that is not the size of the sequence you see this problem. If you have this issue, you can always nest the item(s), then add the Garbage Matte filter to the nest.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • John Fishback
    June 11, 2009 at 9:03 pm
    Email Christoph at CHV. I’m sure there’s a contact email on their site. He’s very responsive.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Roman Bostick
    June 11, 2009 at 9:46 pm
    I did email them and he was most helpful (that’s how we knew about the ‘glitch’…just thought someone else figured out another way around it
    I’ll try the nesting suggestion and see if that works…
    Thank you
  • Roman Bostick
    June 11, 2009 at 9:47 pm
    Thank you – We’re going to try that…
