Activity Forums Adobe After Effects calendar using expressions
  • calendar using expressions
    Posted by Olly Bea on July 19, 2005 at 12:02 pm
    Hey y’all
    OK, i’ve got a problem you can get your teeth into…
    I am trying to make a year-long calendar count up the days and the months… this part is fairly simple (I have made it using a solid layer and the numbers effect, which counts up the days over a period of about 18 seconds)… however and here is where it gets complicated; I need a day counter which runs alongside the calendar (i.e. counts up the days incrementally) which counts from day one up to a maximum of 180 days, but it could appear anywhere throughout the year.
    I am not sure how to do it, it think it may be expressions but I am fairly new to this ‘game’ so could you take me through it nice and slow, or do you have any other ideas?
    Cheers
    Olly
    Filip Vandueren replied 21 years, 2 months ago 2 Members · 4 Replies
  • Filip Vandueren
    July 19, 2005 at 1:22 pm
    Your date is controlled by a slider in the Numbers Effect.
    We can use that value to calculate the days passed since a given day:
    Make a new text-layer and give it’s “Source Text” property this expression:
    dateValue=thisComp.layer("Layer with Numbers effect").effect("Numbers")(4); // change the layerName
    startValue=3675; // the Slider-value at which you want the day counter to be 1
    days=180; // number of days you want to count
    dayCounter=linear(dateValue, startValue-1, startValue+days,0, days)
    if you don’t want the value 0 to be visible untill the counter actually starts running through he days,
    add these next lines:
    if (dayCounter>0) {
    	dayCounter;
    } else {
  • Olly Bea
    July 19, 2005 at 4:06 pm
    A highly complicated expression, although I am having a problem.
    AE is saying;
    After Effects warning: Expected: ;.
    Error occurred at line 1.
    Expression disabled.
    Can you shine any light on this?
    Cheers
    Olly
  • Filip Vandueren
    July 19, 2005 at 8:11 pm
    Did you rename the Layer-name in the first line ?
    Probably something went wrong there, maybe the quotes around the name were not closed correctly.
    Oh,
    and there’s another error in my script (the yellow is the missing bit):
    it should be:
    dayCounter=linear(dateValue, startValue-1, startValue+days-1,0, days)
  • Filip Vandueren
    July 19, 2005 at 9:14 pm
    Oh,
    and don’t copy-paste it from your e-mail,
    go to the website and you’ll see that it looks different: I put some HTML tags in there (all the >code< -stuff )
    to layout it a bit, but in the e-mail they show up in the text, and they’re not supposed to be in the expression
    that’s prob. what went wrong.
