Activity Forums Storage & Archiving caldigit/G-Raid with sata speed problems?
  • caldigit/G-Raid with sata speed problems?
    Posted by John-peter Balas on September 8, 2012 at 2:16 pm
    I have both:
    a CalDigit VR [raid 0]
    and
    a G-Raid [raid 0]
    hooked up to my internal SATA ports on a Gigabyte Z77X-UD5H
    i’m only getting 150mb/sec when i should be getting around 220mb/sec
    I also have another mac with a Sonnet E4P and i’m getting the same speeds when i hook the drives up to that
    Am I doing something wrong? or is this normal?
    John-peter Balas replied 14 years ago 2 Members · 2 Replies
  • Jon Schilling
    September 11, 2012 at 8:43 pm
    John,
    You can try giving CalDigit a call, (I used to work there), but I’m pretty sure that the speeds you’re seeing are within “normal” parameters. The 220MB/s speed you indicated wanting to see is a “theoretical maximum” speed & you wouldn’t necessarily expect to see that, especially out of a 2 drive RAID 0 setup. 4 drives would likely give you a bit more speed, (if they were in 1 enclosure) but not much more….
    Hope this helps.
    Jonathan Schilling
    Vertical Sales Manager
    Proavio Storage by Enhance Technology Inc.
    12221 Florence Ave.
    Santa Fe Springs, CA 90670
    Dir: 562-777-3498
    Main: 562-777-3488 X106
    Fax: 562-777-3499
    Email: jon@proavio.com
  • John-peter Balas
    September 12, 2012 at 7:23 pm
    thanks Jonathan
    turns out i had to repair the disk in osX and that fixed the speed issues
    now i’m back to 216 MB/s read speeds
