Activity › Forums › Apple Final Cut Pro Legacy › Calculating time converting MXF to QT
  • Calculating time converting MXF to QT
    Posted by Joy E reed on February 24, 2010 at 10:36 pm
    Hi, All,
    I know that copying a 15 GB P2 card over a firewire 800 connection should typically take about 9 minutes.
    Is there a simple formula for calculating the approximate amount of time it takes to then convert MXF files to Quicktime files?
    Thanks in advance for your collective expertise!
    Peace & respect,
    Joy E. Reed
    http://www.ohmyproductions.net
    Joy E reed replied 16 years, 7 months ago 3 Members · 3 Replies
  • Shane Ross
    February 24, 2010 at 10:51 pm
    DVCPRO HD? 1GB per min. Basically just a copy with a re-wrap.
    AVCIntra? That’s different. That’s converting to ProRes. I don’t have a time for that.
    Shane
  • Jeremy Garchow
    February 25, 2010 at 1:22 pm
    If using FCP7 you don’t have to go to ProRes bit rather wrap as AVC-I. Much quicker, similar to DVCPro HD.
    I don’t have times either as I typically edit the MXF natively with no log and transfer.
  • Joy E reed
    February 25, 2010 at 2:08 pm
    Hey, Shane,
    Good info! Many thanks. 🙂
    Peace & respect,
    Joy E. Reed
