Activity › Forums › Adobe After Effects › Calculating “Actual CPUs used” in multiprocessing
  • Calculating “Actual CPUs used” in multiprocessing
    Posted by Naveen Mallikarjuna on June 21, 2010 at 11:43 pm
    Am I calculating this wrong? I’m trying to figure out how AE gets it’s “Actual CPUs that will be used”.
    I have 16 GB of RAM. 3 GB is dedicated to other apps, so that leaves 13 GB for AE and the other Adobe vid apps. Right now, they are all NOT running, only AE is running.
    So that’s 13 GB for AE.
    I have 16 CPUs available total. 6 are reserved for other apps. So that leaves me with (potentially) 10 to use for AE.
    If I set the RAM allocation per CPU to 3 GB, and since I have 13 GB available, I would think that would mean 4 CPUs would be used (since that means 12 GB total, the most that can be utilized out of 13 GB).
    Instead, it only uses 3 CPUs. What exactly determines this number?
    Naveen
    Naveen Mallikarjuna replied 16 years, 3 months ago 2 Members · 2 Replies
  • Todd Kopriva
    June 22, 2010 at 12:52 am
    You’re not counting the foreground application. The 3 that is reported is the number of background rendering processes. The foreground process needs to be running, too, and it takes 1,2x the RAM that you’ve allocated to each background process.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Naveen Mallikarjuna
    June 22, 2010 at 2:05 pm
    An answer from the man himself. Thanks Todd!
    Naveen
