Activity Forums Canon Cameras C500 — Internal 1080p recording of Slow/Fast mode?
  • C500 — Internal 1080p recording of Slow/Fast mode?
    Posted by Mark Boszko on May 30, 2014 at 10:04 pm
    We’re considering a C500 at work, and we want to record 4K for the bulk of our footage. Looking at the Ki Pro Quad for doing the 4K recording.
    The vast bulk of what we plan to shoot will be 4K 24p, but I’d like to have the option to shoot overcranked 60-120 for special situations, even if it means doing so at a lower resolution.
    However, it looks like the Ki Pro Quad only records 23.98, 24, 25, and 29.97 with a UHD/4K input, and only up to 59.94 in 2K. And I certainly don’t have the budget to get a Codex Onboard S ($15K!) to be able to record the overcranked 4K.
    Does anyone who’s actually had their hands on a C500 know if the camera will record the full range of 1 to 120 fps to its internal 1080p MPEG-2 format? And is the footage of decent enough quality, to intercut with the 4K recording?
    I realize it won’t be a perfect match, at the lower rez, but it would at least give me an option to work with, if it’s possible.
    Save that, are there any lower budget options for external recording of the overcrank speeds?
    Gary Huff replied 12 years, 2 months ago 3 Members · 3 Replies
  • Mark Boszko
    June 6, 2014 at 11:21 pm
    So… no one’s touched a C500, eh?
  • Frank Tourv
    June 8, 2014 at 5:32 am
    Currently in the exact same situation, and im fairly certain it does not do 120fps Incam. Your best bet for 120fps is the odyssey 7q at 1080p. However i have not tested it yet.
  • Gary Huff
    June 18, 2014 at 1:17 pm
    [frank tourv] “Currently in the exact same situation, and im fairly certain it does not do 120fps Incam.”
    In camera, the C500 is exactly the same as the C300, meaning 720p60 is the highest fps you can record. For anything above 1080p and 60fps, you need the KiPro Quad or the Odyssey 7Q. Keep in mind that the 7Q will not give you compressed recording options at this time, with no date set on when it will be available. Meaning you get CanonRaw at the higher res/frame rates and that’s it with that unit for the time being.
