Activity Forums Maxon Cinema 4D C4D won’t render to picture viewer.
  • C4D won’t render to picture viewer.
    Posted by Paige Lowery on January 13, 2014 at 9:59 pm
    I modeled an object with a few textures and a mat. Each time i try to render to picture viewer cinema says “Files cannot be written-please check output paths.” Why is this happening? Do I need to re-apply the textures?
    Thx 🙂
    Adam Trachtenberg replied 12 years, 7 months ago 4 Members · 6 Replies
  • Tim Shetz
    January 13, 2014 at 10:08 pm
    I’ve seen this happen on some systems when trying to render to the desktop. Usually rendering to a folder on a drive solves it for my students.
    __________
    Tim Shetz
    c4dtraining.com
  • Tim Shetz
    January 13, 2014 at 11:15 pm
    That is…assuming you have entered a path in the File Location on the Save tab of the render settings?
    __________
    Tim Shetz
    c4dtraining.com
  • Jack Cook
    January 15, 2014 at 12:57 pm
    If you’ve got the render settings set to render to a specific folder, but maybe the folder got deleted or moved, then maybe Cinema can’t find the folder to put the render in. This has happened to me in the past. You can render without a location in the Save tab (just leave it blank) if it’s a single picture; then you can save it from the Picture Viewer. But if you’re rendering a sequence and you have no location set, Cinema won’t save the renders.
    Jack
  • Paige Lowery
    January 15, 2014 at 2:58 pm
    I didn’t actually, but I see that now. Thanks so much!
  • Paige Lowery
    January 15, 2014 at 3:00 pm
    Thanks! Problem solved!
  • Adam Trachtenberg
    January 16, 2014 at 7:06 pm
    You can still save animations if you didn’t set a save path. You just have to be sure to change the type (first item) in the Save As dialogue from Still Image to Animation.
