Activity Forums Maxon Cinema 4D C4D Video Backdrop?
  • C4D Video Backdrop?
    Posted by Tim West on December 1, 2006 at 4:52 pm
    I am trying to add a video backdrop plate in C4D to animate over – is this possible and if so how?
    I have tried applying a material with a quicktime as its image, however this doesn’t update in the viewport when I scrub through – something I will need to be able to do.
    Any help would be great!
    Tim
    Brian Jones replied 19 years, 9 months ago 3 Members · 2 Replies
  • Kevin Snyder
    December 1, 2006 at 5:35 pm
    Place a background object in your scene and apply your material with the video to it. Also, make sure that you go to the animation tab on your material and click calculate so the clip will play.
    KMS
  • Brian Jones
    December 1, 2006 at 7:22 pm
    [Tim West] “I have tried applying a material with a quicktime as its image, however this doesn’t update in the viewport when I scrub through – something I will need to be able to do.”
    will work but you have to check Animate Preview in the Illumination tab of the material the QT is in
